danesol
Feb 15, 2022Aspirant
Unable to connect using a browser
All of a sudden when I try and access either the admin page or my own share, i get this message using EDGE or Google Chrome; This site can’t provide a secure connection 192.168.0.10 uses an unsu...
RICHARDA380
Jan 29, 2023Aspirant
Isn't this frustrating!
I could not connect to my ReadyNAS NV+ via my 2 year old Windows PC or a Browser.
So I fired up my old legacy PC from storage, that connected immediatlely into the ReadyNAS NV+ drive. I used this connection to transfer my files from the old "ReadyNAS NV+" to the newer "ReadyNAS 516".
I'll throw out the perfectly working "ReadyNAS NV+" and continue with another NAS. Problem solved (until the newer NAS becomes unsupported by newer versions of Windows!
- StephenBJan 30, 2023Guru - Experienced User
(1) You'd be able to access the shares from file explorer if you'd enabled SMB 1/CIFS on the PC (using "turn windows features on or off").
(2) You'd be able to access from a browser using the information here:
Another option is to use it as part of your backup plan. My own NV+ is on a power schedule, and regularly backs up some shares on my main NAS (an RN526) using rsync. Filesharing protocols are disabled.
