fatihturan
Jan 07, 2022Aspirant
Unexpected shutdown issue
Hi, My ReadyNAS RN-4312X shuts down unexpectedly at midnight. I couldn't find any logs either. It's officially shutting down. What could be the reasons for this? I have the following OS version...
fatihturan
Hi StephenB,
I found log entries similar to the following lines :
file name : status.log
[22/01/07 03:17:44 MSK] warning:volume:LOGMSG_HEALTH_VOLUME Volume rzk.data health changed from Redundant to Degraded.
[22/01/07 03:17:44 MSK] warning:system:LOGMSG_SENT_ALERT_MESG_FAILED Alert message failed to send.
[22/01/07 03:21:44 MSK] crit:disk:LOGMSG_DISK_FAIL_HALT System will be shut down in 30 minutes because of disk failure.
[22/01/07 03:25:51 MSK] info:system:LOGMSG_READYNASD_ABORTED ReadyNASOS service or process (enclosure_monit) was restarted.
[22/01/07 03:25:53 MSK] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
[22/01/07 09:19:25 MSK] info:system:LOGMSG_READYNASD_ABORTED_NOINFO ReadyNASOS service or process was restarted.
[22/01/07 09:19:27 MSK] info:system:LOGMSG_START_READYNASD ReadyNASOS background service started.
Shutdown time approx. 03:30 or 04:00 ...
Jan 07, 2022Guru - Experienced User
There is a setting in the web ui to shut down the system when there is a disk failure. Look in system->settings->alerts, it is likely set there.
You should also look in system.log and kernel.log to get more information on the disk failure.
- fatihturanJan 07, 2022Aspirant
Hi StephenB,
Thank you for all your informations and quickly answers.
I've last question, what's the mean the following log message and is this very critical a message ?
System: ReadyNASOS service or process (enclosure_monit) was restarted.
Kind Regards,
Fatih
- StephenBJan 07, 2022Guru - Experienced User
I don't know why that process was restarted. Looking into the more comprehensive logs around that time (system.log, kernel.log, systemd-journal.log) would likely give more clues.
This could be a side effect of the disk failure, so I suggest that you focus on understanding what disk failed first.
Thank you very much for your help, have a nice day.
