mike_coreit's avatar
mike_coreit
Unsecure connection
Hi, after I log on to https://readycloud.netgear.com the address bar shows that the page is unsecure. Has anyone else noticed this?
I have tried different browsers (Firefox and Edge), also I have tried from a different internet connection.
  • JohnCM_S's avatar
    JohnCM_S
    NETGEAR Employee Retired
    Hi mike_coreit,
    The ReadyCLOUD portal actually runs on HTTPS.
    The reason that you see HTTP when you login into the portal is for our home routers where they also connect to ReadyCloud however due to their specifications they usually are having a hard time maintaining HTTPS connection due to certificates being updated from time to time. So seeing the portal on HTTP is just actually for the routers to be able to use its feature but ensuring back-end and other access is secured using HTTPS and VPN connections.
  • JohnCM_S's avatar
    JohnCM_S
    Hi mike_coreit,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
    The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
