spotcatbug
Dec 05, 2015Apprentice
Upgraded from 6.4.0 to 6.4.1... external backup drive disappeared...
Every frickin upgrade is an adventure. Anyway... RN104 was running 6.4.0. Nightly backups to external USB drive were working perfectly. The same day that I upgraded to 6.4.1, I got a message t...
BrianL2
Dec 06, 2015NETGEAR Employee Retired
Hi spotcatbug,
Plug in your external storage device in your PC and run the windows disk error checking feature. Once it finished the scan, plug it back to the ReadyNAS and see if it shows up. Also, try other external storage devices to isolate.
Kind regards,
BrianL
NETGEAR Community Team
- mdgm-ntgrDec 07, 2015NETGEAR Employee Retired
Which filesystem is on the USB disk?
- xkellerDec 07, 2015Aspirant
I have the same problem, with my USB disk 500Go (the filesystem is NTFS). Very slow backups.
- spotcatbugDec 07, 2015Apprentice
