jonalexfilms
Oct 25, 2016Aspirant
Upgraded to 6.6.0 and am now having performance issues
After upgradiing my firmware to 6.6.0 access to my netword raid is almost unusable. We have a pretty stable network with a small user base and have tried different forms of access to the raid via ne...
- Oct 25, 2016
Try disabling IPv6 on the NAS.
jonalexfilms
Hello StephenB, thanks for your reply.
I went under Network -> Links, clicked on the gear and see that both ipv4 and ipv6 are active. ipv4: using DHCP and ipv6 : Automatically/DHCP
Oct 25, 2016Guru - Experienced User
- jonalexfilmsOct 25, 2016Aspirant
That seems to be it! Thanks
oh man, now I did it.
It went back to slow performance, and I thought it might be a good idea to switch from ipV4 to ipV6.... and now I can't access the admin.
I've restarted the NAS and no dice.
Boot mode -> OS Reinstal {sigh}
- jonalexfilmsOct 28, 2016Aspirant
Just to wrap this up....
I continued having poor performance even after disabling ipv6.
All of the computers on our network are running MacOS, so I had set the acess to all my shares as AFP, however, I tried adding SMB access to all the shares and voilà... problem fixed.
I even enabled ipv6 again, and things continue to run smoothly.
- FramerVOct 28, 2016NETGEAR Employee Retired
Hi jonalexfilms,
Thank you very much for the feedback. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
