Vyper007
Jan 15, 2013Aspirant
UPS Shutdown Threshold ?
Hi I've got an APC 700KVA UPS attached to my Readynas Ultra 6+, theres an option to set what battery threshold the Readynas will shut down at in the event of a power cut, however what I cant find in t...
chirpa
Jan 15, 2013Luminary
Auto uses whatever the UPS has set inside itself. You may be able to use PowerChute software on Windows to configure it. I believe the default is 60%.
