RonSchmiege
Jan 24, 2016Tutor
USB drives that work with RN104 & firmware 6.4.1 +
Anyone know which USB drives work properly with RN104 & firmware 6.4.1 and up. (Also if you know of one that doesn't work.) I need to replace my USB backup drive, a Seagate GoFlex with USB 3.0 which doesn't work since the 6.4.1 update.
- mdgm-ntgrNETGEAR Employee Retired
Which USB port is the GoFlex connected to?
Which filesystem is on this USB disk?Which services and apps are you running?
What problem are you having with the USB disk?
- BrianL2NETGEAR Employee Retired
Hi RonSchmiege,
The RN100 series devices have one front port, USB version 2.0, and 2 rear ports, USB version 3.0. It recognizes USB drives with FAT32, EXT3/4, NTFS and HFS format.
Hope this helps!
Kind regards,
BrianL
NETGEAR Community- StephenBGuru - Experienced User
btrfs was just added to 6.4.2 beta.
Skywalker wrote:
- [Beta 1] Recognize BTRFS filesystems in USB drives.
BTW, all this should be in the software manual (and not just the data sheet). It isn't.
