ExecRecruiter
Dec 05, 2016Aspirant
USB Passport Ultra not seen by ReadyNas 10200
Readynas 102 2 drive unit. Following is a reconstruction. Connected Passport Ultra #1 to backup up ready nas on rear upper port. Formatted EX4. Back up completed with automatic dismount. Rec...
- Dec 11, 2016
Hi ExecRecruiter,
There is known issue on USB connections to the ReadyNAS. You can consider using a BETA firmware to fix it.
ReadyNASOS 6.6.1-T220 (Beta 3)
ExecRecruiter
Hmm. found the USB cable loose. Might have something to do with unreliability. Doing further testing.
