ExecRecruiter
Dec 05, 2016Aspirant
USB Passport Ultra not seen by ReadyNas 10200
Readynas 102 2 drive unit. Following is a reconstruction. Connected Passport Ultra #1 to backup up ready nas on rear upper port. Formatted EX4. Back up completed with automatic dismount. Rec...
- Dec 11, 2016
Hi ExecRecruiter,
There is known issue on USB connections to the ReadyNAS. You can consider using a BETA firmware to fix it.
ReadyNASOS 6.6.1-T220 (Beta 3)
ExecRecruiter
Dec 11, 2016Aspirant
Mr Framer.
I Thank you for the query. I have done some more testing.
Here are the results. I made sure on each change that the USB cable was properly plugged in, since it apparently is in rebellion mode and will unplug itself.
My prefence was to use NTFS so I could access the Passport Backups via Windows 10. However I was unable to consistently complete backups. Several times it stopped halfway through with no error message. I have a feeling, but could not verify, that ejection of the disk formatted as NTFS was not consistent. I felt this way because I could not get the disk to be re- recognised, even after a power off and power on of the ReadyNas. I only had success in this after reformatting the disk on the Windows computer.
All these tests are on the rear upper USB Port. I believe its a USB3.
I got similar results on the front port, but got tired of waiting. I think its a USB2.
EXT4 Disk. Plugged In Disk 2. NAS Recognised it. Ejected Disk 2
BTRFS Plugged In Disk 1. Not Recognised. NAS Turned off, then On
Recognised. Eject Disk 1. Unplugged Disk 1. Replugged in Disk 1
EXT4 Disk2 Plugged in Disk 2. Recognised, (Note. This is behavior I would expect if hot plug works)
Eject Disk 2. Unplugged Disk 2.
EXT4 Disk 2 Replug in Disk 2. Not recognised. ( Note. Wierd. Why recognised last time and not this)
Unplugged Disk 2
BTRFS Disk 1 Plug in Disk 1 Not recognised. UnPlugged Disk 1
EXT4 Disk 2 Plug in Disk 2 Not recognised. NAS turn off, then On.
Recognised. Reformatted Disk 1 from EXT4 to BTRFS ( a few seconds)
Run Backup Job From NAS to Disk 1. Change Access rights from Everyone to Admin. ( Why default to everyone? )
Start 2:34. End 3:02 Roughly 30 minutes for 50 Gigabytes. Given how slow these disks are, that is incredible speed and much faster than NTFS, which actually never finished. Backup job includes automatic eject when finished. I must admit I wonder if everything got copied.
From this point on, for about 5 cycles, the disks would not be recognised unless the NAS was turned off, then on. This was true whether the disks were connected before or after the power cycle. With the power cycle they were recognised everytime. Reminded me of TRSDOS.
These are my tentative conclusions.
On my system, backups using NTFS are unreliable. When they dont complete, I develop trust issues.
EXT4 and BTRFS both seem to work quickly. BTRFS is much faster. I haven't been able to completely check integrity.
The NAS must have its power recycled in order to change back up disks. ( Hotplugging disks into the USB port worked once, and then it didnt work for the rest of my tests.)
Is this consistent with other experinces.
Thanks.
Larry
FramerV
Dec 11, 2016NETGEAR Employee Retired
Hi ExecRecruiter,
- ExecRecruiterDec 11, 2016Aspirant
That Beta seems to have fixed the fixed the recognition problem. Thank you.
- FramerVDec 12, 2016NETGEAR Employee Retired
Hi ExecRecruiter,
You are welcome, glad I could help.
