stevenparker0's avatar
Oct 04, 2025
Using ReadyNAS as backend for lightweight web tools — is it reliable?
Hi everyone,
I currently maintain a small web tool (for example a gratuity / end-of-service benefit calculator for users in the UAE), and I’m evaluating options to host user data, logs, JSON storage files, and backups. My ideal setup is a lightweight, always-on system without needing a full server. That’s where ReadyNAS caught my interest.
Some of the things I’m considering:
Using ReadyNAS to host REST APIs, static JSON or YAML config files, and backing up user session data.
Ensuring data integrity and performance — especially under concurrent access.
Handling firmware updates without breaking API endpoints.
Syncing backups to cloud or another NAS for redundancy.
A few questions for those experienced with ReadyNAS:
1. Has anyone used ReadyNAS to back a small web service or tool (not just file server)?
2. What is the maximum recommended concurrent requests for lightweight API files (JSON) on ReadyNAS?
3. Which methods have you used for version-safe firmware updates so that custom services are not lost?
4. How do you handle secure access (SSL, tokens) when serving APIs from a NAS that’s also storing private user data?
If anyone’s already built similar backend or microservice setups using ReadyNAS, I’d love pointers or pitfalls to avoid. Thank you!
  • StephenB's avatar
    All ReadyNAS platforms are end-of-life:
    1. The newest platforms use Debian 8 (Jessie), which was deprecated in 2020.
    2. Netgear hasn't provided a firmware update since Jan 2024.
    3. The version of apache is 2.4.25 (built in Feb 2019).
    4. Netgear's repo has been taken down, which will get in the way of installing or updating packages.
    I don't recommend setting up a website using ReadyNAS, since there won't be any more security updates.
  • Great question! I've seen similar lightweight setups work well for small web tools.
    For concurrent JSON file access on ReadyNAS, keeping requests under 50 concurrent is generally safe for lightweight tools. Beyond that, you risk I/O bottlenecks.
    For firmware updates, the safest approach is to run your custom services inside Docker containers this way firmware updates don't touch your service configuration.
    For SSL and token-based auth, a reverse proxy like Nginx sitting in front of your NAS API endpoints works reliably even on low-power hardware.
    We actually use a similar minimal backend approach for our calculadora de datas online a date calculation tool for Brazilian users. Keeping all calculation logic client-side and serving only static JSON config files from the backend made it extremely lightweight and reliable under concurrent access. ReadyNAS type setups work perfectly for this kind of architecture.
    Hope this helps!
    • StephenB's avatar
      They are all EoL, and haven't gotten security updates for a couple of years now.  I do not recommend connecting them to the open internet.
ProSupport for Business
