frankpdx
Sep 24, 2016Aspirant
Using readynas formatted disks in a EDA 500
I have one slot available in my readynas 516. If I switch out all my hard drives with higher capacity disk, is it possible to use my old drives in the eda500 as they are still good, they are just less...
frankpdx
Thank you moderator.
The reason why I want to do this is I run a Plex server on my readynas, this is why I want to add an EDA500. If I get the RN316, will I be able to add it to a plex share on my RN516 as I do not think this will be possible because if this is the case, it seems I should have never bought a 516 at all as I thought I could just daisy chain EDA500s.
Thank you,
Frank
Thank you,
Frank
- StephenBSep 24, 2016Guru - Experienced User
frankpdx wrote:
I thought I could just daisy chain EDA500s.You can (creating separate volumes on each). mdgm is just pointing out that performance of a RN516+RN316 is generally better than an RN516+EDA500. Two CPUs instead of one, four NICs instead of two...
frankpdx wrote:
If I get the RN316, will I be able to add it to a plex share on my RN516 as I do not think this will be possibleThis is easy to do with plex running on a Windows PC (just enter \\nasname\sharename when you add a folder). But I don't think that will work with the linux plex server - I think you'd have to mount the share on the RN516. That is possible with ssh, but it would take some work if you want it to automount.
- frankpdxSep 24, 2016Aspirant
Thank you for the response.
it appears I was wrong about the capabilities of the 516 as a plex server.
thank you,
Frank
- StephenBSep 25, 2016Guru - Experienced User
I'm confused about what you mean here. Can you tell us what are wanting it to do?
Neither mdgm nor I said the NAS won't stream with plex with EDA500s attached.
BTW, how much space do you need for your library now, and what disks are installed in the RN516?
