bobinatcat
Sep 27, 2011Aspirant
Very slow NV+... PLEASE help!
Hi all, Sorry I know you must all be sick of this :oops: Anyway here goes. My NV+ is connected to a Linksys WAG160N (firmware updated this morning) yet i get terrible speeds. Also the pc is ...
mdgm-ntgr
Sep 27, 2011NETGEAR Employee Retired
Not having gigabit slows down to roughly 10MB/s. 12.5MB/s is theoretical limit of 100 Mbit ethernet, but 10MB/s is realistic. Wireless is slower still.
I'm not sure what router to recommend. If adding an additional router consider the WNDR3700. IF you want to replace your router/adsl2 modem I'm not so sure
Was that 8MB/s over ethernet or wireless?
The Definitive Guide to the ReadyNAS NV+
if not wanting to backup the backup share to a usb disk you'll need to create backup jobs under Backup > Add a new backup job. Then when looking at the list of backup jobs scroll down and assign the relevant backup job(s) to the backup button.
yoh-dah wrote:
If you think we’re obsessed about backups, you might be right. Another option for backups is through the use of the backup button on the front of the ReadyNAS. By default, pressing the button will backup your backup share on the ReadyNAS to the attached USB storage device next to the button.
If you prefer, you can assign any or all of the backup jobs to the Backup Button. If you press the button, all jobs assigned to the button will run sequentially.
