uptown30
Jan 11, 2017Guide
Volume Data degraded error
Hi we have a Netgear 314E, Raid 5 and I keep getting this error. I have fixed it once by running balance and defrag but it is back again. The firmware is 6.6.0 and we have Egnyte Storage sync runni...
- Jan 14, 2017
Hi uptown30,
I think the problem is with this:
Device: sda
Controller: 0
Channel: 0
Firmware: 01.01K02
Class: SATA
RPM: 7200
Sectors: 3907029168
Pool: data
PoolType: RAID 5
PoolState: 3
PoolHostId: 7c6e33a8
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 31
Uncorrectable Sector Count: 31
Temperature: 44
Start/Stop Count: 15
Power-On Hours: 23184
Power Cycle Count: 15
Load Cycle Count: 6There are uncorrectable and pending sectors already. Normally these are indicators that the HDD is faulty or getting there.
Are you using X-RAID2?
Volume in a degraded state as far as I know should still work, it just cannot tolerate anymore HDD failure.
I would suggest that you try to do a back-up of your files then have the HDD above be checked then replaced.
Jan 11, 2017Guru - Experienced User
uptown30 wrote:
This is the disk log. What is it indicating?
Device: sda
Controller: 0
Channel: 0
This says that disk 1 (Channel 0) is starting to fail. There might be other issues that show up in other logs (mdstat.log for instance).
Balance and defrag won't fix degraded volume errors btw. Only resyncing the array can do that.
uptown30
Jan 11, 2017Guide
If we do have to resync the array, does this means I have to back up the data, break the array and recreate it?
- mdgm-ntgrJan 11, 2017NETGEAR Employee Retired
sda is marked as failed on the data volume array. I would replace that disk.
- uptown30Jan 11, 2017Guide
I have just rebooted the NAS and now it is indicating it is resyncing the volume however under System, Performance, Status it does indicate a yellow dot to Disk 1. Okay if I have to replace it, can I get some guidance what I have to do? I will order a 2 TB drive for one thing tomorrow.
mdgm - the NAS is less than 4 years old since it was purchased and base on the Hardware compadabilty list (http://kb.netgear.com/20641/ReadyNAS-Hard-Disk-Compatibility-List), it indicated there is a warranty of 5 years on from the manufacturer. So would that means I can get in touch with Netgear or would I have to get in touch with who we purchase the unit from for a disk replacement? Or the warrantly only valid if we have purchased a warranty coverage with Netgear? your input would be appreciated.
Actually the resync of the disk 1 is complete and the status is that the disk is healthy. Not sure if I should still pursue to get the disk replace.
- StephenBJan 12, 2017Guru - Experienced User
If you are the original purchaser of the RN314E (with Netgear-installed enterprise disks) then you should contact Netgear. Download the logs and check the SMART stats for the disk - don't just rely on the volume health indication.
