uptown30
Jan 11, 2017Guide
Volume Data degraded error
Hi we have a Netgear 314E, Raid 5 and I keep getting this error. I have fixed it once by running balance and defrag but it is back again. The firmware is 6.6.0 and we have Egnyte Storage sync runni...
- Jan 14, 2017
Hi uptown30,
I think the problem is with this:
Device: sda
Controller: 0
Channel: 0
Firmware: 01.01K02
Class: SATA
RPM: 7200
Sectors: 3907029168
Pool: data
PoolType: RAID 5
PoolState: 3
PoolHostId: 7c6e33a8
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 31
Uncorrectable Sector Count: 31
Temperature: 44
Start/Stop Count: 15
Power-On Hours: 23184
Power Cycle Count: 15
Load Cycle Count: 6There are uncorrectable and pending sectors already. Normally these are indicators that the HDD is faulty or getting there.
Are you using X-RAID2?
Volume in a degraded state as far as I know should still work, it just cannot tolerate anymore HDD failure.
I would suggest that you try to do a back-up of your files then have the HDD above be checked then replaced.
uptown30
Jan 12, 2017Guide
Yes the company is the originator purchaser. I will get in touch with Netgear. I did send all the logs to mdmg. Would the Netgear requires the logs you have indicated?
- StephenBJan 12, 2017Guru - Experienced User
uptown30 wrote:
Would the Netgear requires the logs you have indicated?That I don't know. But it makes sense for you to look in smart_history.log and then decide on disk replacement.
- uptown30Jan 12, 2017Guide
Where do i see the smart_history logs? I have just downloaded the entire log folder but nada.
- FramerVJan 14, 2017NETGEAR Employee Retired
Hi uptown30,
Device: sda
Controller: 0
Channel: 0
Firmware: 01.01K02
Class: SATA
RPM: 7200
Sectors: 3907029168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 44
