uptown30
Jan 11, 2017Guide
Volume Data degraded error
Hi we have a Netgear 314E, Raid 5 and I keep getting this error. I have fixed it once by running balance and defrag but it is back again. The firmware is 6.6.0 and we have Egnyte Storage sync runni...
- Jan 14, 2017
Hi uptown30,
I think the problem is with this:
Device: sda
Controller: 0
Channel: 0
Firmware: 01.01K02
Class: SATA
RPM: 7200
Sectors: 3907029168
Pool: data
PoolType: RAID 5
PoolState: 3
PoolHostId: 7c6e33a8
Health data
ATA Error Count: 0
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 31
Uncorrectable Sector Count: 31
Temperature: 44
Start/Stop Count: 15
Power-On Hours: 23184
Power Cycle Count: 15
Load Cycle Count: 6There are uncorrectable and pending sectors already. Normally these are indicators that the HDD is faulty or getting there.
Are you using X-RAID2?
Volume in a degraded state as far as I know should still work, it just cannot tolerate anymore HDD failure.
I would suggest that you try to do a back-up of your files then have the HDD above be checked then replaced.
uptown30
Jan 12, 2017Guide
Yes the company is the originator purchaser. I will get in touch with Netgear. I did send all the logs to mdmg. Would the Netgear requires the logs you have indicated?
Jan 12, 2017Guru - Experienced User
That I don't know. But it makes sense for you to look in smart_history.log and then decide on disk replacement.
- uptown30Jan 12, 2017Guide
Where do i see the smart_history logs? I have just downloaded the entire log folder but nada.
- FramerVJan 14, 2017NETGEAR Employee Retired
Hi uptown30,
Device: sda
Controller: 0
Channel: 0
Firmware: 01.01K02
Class: SATA
RPM: 7200
Sectors: 3907029168
Pool: data
PoolType: RAID 5
PoolState: 3
Health data
ATA Error Count: 0
Spin Retry Count: 0
Temperature: 44
- FramerVJan 21, 2017NETGEAR Employee Retired
Hi uptown30,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
