jarri
Mar 30, 2014Aspirant
Volume expansion fails even after factory default
Hi, I've got a problem with Readynas Pro Business Edition. I've got 3 x 4TB + 3 x 3TB. Changed 4th 3TB to 4TB and expansion failed. It's OK since I probably passed the 8TB limit. I've made a fresh ba...
mdgm-ntgr
Mar 30, 2014NETGEAR Employee Retired
jarri wrote:
So it's not possible to expand with the capacity I currently have in all six bays? If I wanted to stay with single-redundancy then in X-RAID2 it should initialize after factory default with much bigger volume and it actually should accept that config of 4x4TB + 2x3TB? Why it fails then? Why would I need 6 same disks?
It creates a 6x3TB RAID-5 layer then attempts to expand to use the extra space on the 4TB disks and fails.
jarri wrote:
As I understand volume expansion is not possible AT ALL after I pass the limit of 16 TB? I mean I wouldn't be able to change those last 3TB disks to 4TB disks and expand volume even though I do not pass 8TB expansion limit?
Correct. That's why the use of Flex-RAID where you can have multiple volumes or upgrading to ReadyNAS OS 6 which does not have these expansion limitations would be worth considering.
