jarri
Mar 30, 2014Aspirant
Volume expansion fails even after factory default
Hi, I've got a problem with Readynas Pro Business Edition. I've got 3 x 4TB + 3 x 3TB. Changed 4th 3TB to 4TB and expansion failed. It's OK since I probably passed the 8TB limit. I've made a fresh ba...
mdgm-ntgr
Mar 30, 2014NETGEAR Employee Retired
With 6.1.7 there is fan control for the Pro, but I understand the support reason for you not wishing to use it.
Yes, there is no way to expand past 16TB on 4.2.x. Multiple volumes using Flex-RAID would be the way to go.
