jarri
Mar 30, 2014Aspirant
Volume expansion fails even after factory default
Hi, I've got a problem with Readynas Pro Business Edition. I've got 3 x 4TB + 3 x 3TB. Changed 4th 3TB to 4TB and expansion failed. It's OK since I probably passed the 8TB limit. I've made a fresh ba...
mdgm-ntgr
Mar 30, 2014NETGEAR Employee Retired
You could use a modified image to update to 6.1.6 then update to 6.1.7 RC or modify 6.1.7 RC to go direct to the RC. See http://www.readynas.com/forum/viewtopic.php?f=35&t=70323
