jarri
Mar 30, 2014Aspirant
Volume expansion fails even after factory default
Hi, I've got a problem with Readynas Pro Business Edition. I've got 3 x 4TB + 3 x 3TB. Changed 4th 3TB to 4TB and expansion failed. It's OK since I probably passed the 8TB limit. I've made a fresh ba...
jarri
Something is definetly wrong. It created two volumes. Both RAID 5. First is 13,62TB and is empty, but status is unknown (there is statement RESYNC - 0%, time: NaN:NaN:NaN). And second one is data:0, free: 0. It does resync of this volume. It is not possible to remove it. Systems keeps showing alerts every couple of minutes.
- Volume 'data' health changed from 'redundant' to 'inactive' and opposite.
- To use disk, remove inactive volumes. Disks 1,2,3,4 (translation from my native language)
Also it shows the second volume (with data: 0) as configured on disks 1,2,3,4.
