kalayl1
Jun 17, 2013Aspirant
Volume 'root' usage is 84%
I've had my ReadyNAS 314 for almost three weeks now and have been mostly having a good experience. This evening I received this log alert: Volume: System volume 'root' usage is 84 %. This con...
mountaindude
Aug 15, 2013Tutor
StephenB wrote:
Check Crashplan's cache size (/usr/local/crashplan/cache). Probably the guide should be revised, telling folks to put the cache on the data volume.
Yep, did that and it's about 300 MB. Deleting it will cause the cache to be rebuilt though, but it should be smaller at least.
Still it would be better to have this on a non root partition - I agree.
Can't seem to find where CrashPlan sets the log location though.. will dig in a bit more.
Edit: Same thing with the log files in /usr/local/crashplan/log too. Should be moved to non-root partition.
