kalayl1
Jun 17, 2013Aspirant
Volume 'root' usage is 84%
I've had my ReadyNAS 314 for almost three weeks now and have been mostly having a good experience. This evening I received this log alert: Volume: System volume 'root' usage is 84 %. This con...
Sep 25, 2013Guru - Experienced User
There is a variable in /usr/local/crashplan/conf/my.service.xml that holds the cache location. I haven't tried changing it, so I don't know what would happen if you did. I don't see anything about the logs.
You could also try creating a soft link to the /c/ volume somewhere.
