Bowlinra
Aug 23, 2009Aspirant
Volume scan failed to run properly.
I can't seem to fix this scan problem or get the snapshots to work anymore. Here the issues & timeline: Aug 16: "Reallocated sector count has increased in the last day. Disk 1: Previous count: 0 C...
mdgm-ntgr
Aug 27, 2009NETGEAR Employee Retired
Bowlinra wrote: I also just got an ReadyNAS 1100. Should I correct the volume scan failure on the 1000S, before moving the disk to the 1100? or is better address in the 1100?
Moving to the 1100 is as simple as (hopefully?):
1. Install the All disk in same numbered slots
2. Boot NAS
3. Upgrade Firmware
4. Recalibrate the fan speed
Is the volume scan the same as a volume check? See faq.php#How_can_I_skip_the_Volume_check%3F
Not sure whether technical support will help you if you have issues moving from an out of warranty ReadyNas to a new one.
I'd wait for Jedi to comment on whether it's ok to move your disks to your new ReadyNas or not with a failed volume scan.
Your procedure for migrating disks should be fine. See faq.php#How_do_I_migrate_disks_over_from_an_existing_ReadyNAS_to_another%3F'
You may need to do a USB Boot Recovery and Firmware Re-install when you've moved the disks to the new ReadyNas.
See faq.php#How_can_I_perform_a_Boot_Recovery_using_a_USB_flash_device%3F
then faq.php#How_do_I_re-install_the_firmware%3F
