Bowlinra
Aug 23, 2009Aspirant
Volume scan failed to run properly.
I can't seem to fix this scan problem or get the snapshots to work anymore. Here the issues & timeline: Aug 16: "Reallocated sector count has increased in the last day. Disk 1: Previous count: 0 C...
Bowlinra
Aug 27, 2009Aspirant
It's a Volume scan failure.
Sat Aug 22 03:17:36 EDT 2009 Unsuccessful taking snapshot.
Fri Aug 21 21:46:26 EDT 2009 System is up.
Fri Aug 21 21:45:20 EDT 2009 Volume scan failed to run properly.
Fri Aug 21 20:47:31 EDT 2009 System powering off...
Sun Aug 16 04:00:08 EDT 2009 Reallocated sector count has increased in the last day. Disk 1: Previous count: 0 Current count: 1 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
Sat May 16 18:09:58 EDT 2009 Snapshot successfully taken.
