Elanthius
Feb 09, 2012Aspirant
Volume scan regularly finds large number of errors
I've only had the box for a few days but twice now on reboots I'm getting emails like below. This seems like an awful lot of errors for such a short period of time. Should I be concerned? Normally if I see a lot of fixes like this I also expect to lose a few files. Is that happening here? There has been no power outage or unexpected shutdown. This email was sent after I scheduled a reboot from the web interface. Incidentally the reason I chose to reboot the box is that I had second instance of a locked file giving "Text file busy" error when trying to do anything with it in linux over CIFs mount.
*edit: This is for a readynas nv+ v2.
***** File system check performed at Fri Feb 10 05:32:32 WET 2012 *****
fsck from util-linux-ng 2.17.2
e2fsck 1.41.14 (22-Dec-2010)
Pass 1: Checking inodes, blocks, and sizes
Inode 14293302, i_blocks is 2862584, should be 2863096. Fix? yes
Inode 16745056, i_blocks is 842328, should be 842512. Fix? yes
Inode 16941088, i_blocks is 622872, should be 622928. Fix? yes
Inode 16973830, i_blocks is 1139304, should be 1139456. Fix? yes
Inode 16973831, i_blocks is 1140000, should be 1140184. Fix? yes
Inode 16973832, i_blocks is 1140744, should be 1140920. Fix? yes
Inode 17432590, i_blocks is 151648, should be 151656. Fix? yes
Inode 17432591, i_blocks is 80496, should be 80504. Fix? yes
Inode 17432592, i_blocks is 45648, should be 45656. Fix? yes
Inode 17596575, i_blocks is 9155832, should be 9156928. Fix? yes
Inode 17596576, i_blocks is 9168056, should be 9168704. Fix? yes
Inode 17596577, i_blocks is 9155144, should be 9155816. Fix? yes
Inode 17596578, i_blocks is 4580800, should be 4581136. Fix? yes
Inode 17596585, i_blocks is 82336, should be 82344. Fix? yes
Inode 17596587, i_blocks is 6874264, should be 6874920. Fix? yes
Inode 17596588, i_blocks is 6873608, should be 6874288. Fix? yes
Inode 17596589, i_blocks is 6871584, should be 6872264. Fix? yes
Inode 17596761, i_blocks is 4583584, should be 4583712. Fix? yes
Inode 17596764, i_blocks is 5722504, should be 5722752. Fix? yes
Inode 17596767, i_blocks is 6872616, should be 6873552. Fix? yes
Inode 17596770, i_blocks is 7637880, should be 7637952. Fix? yes
Inode 17596773, i_blocks is 9165224, should be 9165352. Fix? yes
Inode 17596776, i_blocks is 4581456, should be 4581640. Fix? yes
Inode 17596779, i_blocks is 6107000, should be 6107008. Fix? yes
Inode 17596785, i_blocks is 9152800, should be 9152992. Fix? yes
Inode 17596788, i_blocks is 9155344, should be 9155616. Fix? yes
Inode 17596791, i_blocks is 2290712, should be 2290784. Fix? yes
Inode 17596792, i_blocks is 13753224, should be 13753368. Fix? yes
Inode 17596795, i_blocks is 9152816, should be 9152936. Fix? yes
Inode 17596798, i_blocks is 5126016, should be 5126112. Fix? yes
Inode 17596802, i_blocks is 9164312, should be 9164504. Fix? yes
Inode 17596808, i_blocks is 6864760, should be 6864776. Fix? yes
Inode 17596924, i_blocks is 3060240, should be 3060456. Fix? yes
Inode 17596927, i_blocks is 2299112, should be 2299232. Fix? yes
Inode 17596928, i_blocks is 3060824, should be 3061016. Fix? yes
Inode 17596930, i_blocks is 3192232, should be 3192248. Fix? yes
Inode 17596933, i_blocks is 2295968, should be 2296104. Fix? yes
Inode 17596935, i_blocks is 3061376, should be 3061400. Fix? yes
Inode 17596936, i_blocks is 2299272, should be 2299480. Fix? yes
Inode 17596937, i_blocks is 3045136, should be 3045248. Fix? yes
Inode 17596939, i_blocks is 486520, should be 486544. Fix? yes
Inode 17596940, i_blocks is 99624, should be 99632. Fix? yes
Inode 17596986, i_blocks is 1433240, should be 1433384. Fix? yes
Inode 17629238, i_blocks is 195320, should be 195376. Fix? yes
Inode 17629239, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629240, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629241, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629242, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629243, i_blocks is 195320, should be 195376. Fix? yes
Inode 17629244, i_blocks is 195320, should be 195336. Fix? yes
Inode 17629245, i_blocks is 195320, should be 195336. Fix? yes
Inode 17629246, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629247, i_blocks is 195320, should be 195336. Fix? yes
Inode 17629248, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629249, i_blocks is 195320, should be 195336. Fix? yes
Inode 17629250, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629251, i_blocks is 195320, should be 195336. Fix? yes
Inode 17629252, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629253, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629254, i_blocks is 195320, should be 195368. Fix? yes
Inode 17629255, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629256, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629257, i_blocks is 195320, should be 195400. Fix? yes
Inode 17629258, i_blocks is 195320, should be 195368. Fix? yes
Inode 17629259, i_blocks is 195320, should be 195368. Fix? yes
Inode 17629260, i_blocks is 195320, should be 195336. Fix? yes
Inode 17629261, i_blocks is 195320, should be 195336. Fix? yes
Inode 17629262, i_blocks is 185224, should be 185240. Fix? yes
Inode 17629263, i_blocks is 195320, should be 195368. Fix? yes
Inode 17629264, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629265, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629266, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629267, i_blocks is 195320, should be 195336. Fix? yes
Inode 17629268, i_blocks is 195320, should be 195336. Fix? yes
Inode 17629269, i_blocks is 195320, should be 195368. Fix? yes
Inode 17629270, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629271, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629272, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629273, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629274, i_blocks is 195320, should be 195376. Fix? yes
Inode 17629275, i_blocks is 195320, should be 195368. Fix? yes
Inode 17629276, i_blocks is 195320, should be 195368. Fix? yes
Inode 17629277, i_blocks is 195320, should be 195440. Fix? yes
Inode 17629278, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629279, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629280, i_blocks is 195320, should be 195376. Fix? yes
Inode 17629281, i_blocks is 195320, should be 195376. Fix? yes
Inode 17629282, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629283, i_blocks is 195320, should be 195376. Fix? yes
Inode 17629284, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629285, i_blocks is 195320, should be 195336. Fix? yes
Inode 17629286, i_blocks is 195320, should be 195368. Fix? yes
Inode 17629287, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629288, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629289, i_blocks is 195320, should be 195328. Fix? yes
Inode 17629290, i_blocks is 195320, should be 195352. Fix? yes
Inode 17629291, i_blocks is 195320, should be 195368. Fix? yes
Inode 17629292, i_blocks is 195320, should be 195368. Fix? yes
Inode 17629293, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629294, i_blocks is 195320, should be 195368. Fix? yes
Inode 17629295, i_blocks is 195320, should be 195344. Fix? yes
Inode 17629298, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629299, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629300, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629301, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629302, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629303, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629304, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629305, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629306, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629307, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629308, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629309, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629310, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629311, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629312, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629313, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629314, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629315, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629316, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629317, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629318, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629319, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629320, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629321, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629322, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629323, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629324, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629326, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629327, i_blocks is 22760, should be 22768. Fix? yes
Inode 17629328, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629329, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629330, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629331, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629332, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629333, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629334, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629335, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629336, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629337, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629338, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629339, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629340, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629341, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629342, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629343, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629344, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629345, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629346, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629347, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629348, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629349, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629350, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629351, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629352, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629354, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629355, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629356, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629357, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629358, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629359, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629360, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629361, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629362, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629363, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629364, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629365, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629366, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629367, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629368, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629369, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629370, i_blocks is 97664, should be 97688. Fix? yes
Inode 17629371, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629372, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629373, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629374, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629375, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629376, i_blocks is 97664, should be 97680. Fix? yes
Inode 17629377, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629378, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629379, i_blocks is 97664, should be 97672. Fix? yes
Inode 17629381, i_blocks is 77368, should be 77392. Fix? yes
Inode 17629384, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629385, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629386, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629387, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629388, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629389, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629390, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629391, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629392, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629393, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629394, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629395, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629396, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629397, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629398, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629399, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629400, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629401, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629402, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629403, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629404, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629405, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629406, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629407, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629408, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629409, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629410, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629411, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629412, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629413, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629414, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629415, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629416, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629417, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629418, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629419, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629420, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629421, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629422, i_blocks is 29304, should be 29312. Fix? yes
Inode 17629423, i_blocks is 3392, should be 3400. Fix? yes
Inode 17629782, i_blocks is 1425072, should be 1425256. Fix? yes
Inode 17629785, i_blocks is 1423080, should be 1423256. Fix? yes
Inode 17629788, i_blocks is 1433032, should be 1433160. Fix? yes
Inode 17629789, i_blocks is 1430808, should be 1430976. Fix? yes
Inode 17629792, i_blocks is 1433496, should be 1433608. Fix? yes
Inode 17629793, i_blocks is 619976, should be 619984. Fix? yes
Inode 17629827, i_blocks is 16597288, should be 16598696. Fix? yes
Inode 17629828, i_blocks is 17416, should be 17424. Fix? yes
Inode 17629878, i_blocks is 5550944, should be 5551680. Fix? yes
Inode 17629879, i_blocks is 4582064, should be 4582152. Fix? yes
Inode 17629880, i_blocks is 4582176, should be 4582184. Fix? yes
Inode 17629883, i_blocks is 4581992, should be 4582040. Fix? yes
Inode 17629884, i_blocks is 5550320, should be 5550400. Fix? yes
Inode 17629887, i_blocks is 4578280, should be 4578424. Fix? yes
Inode 17629888, i_blocks is 6874536, should be 6874736. Fix? yes
Inode 17629889, i_blocks is 4579440, should be 4579568. Fix? yes
Inode 17629891, i_blocks is 4576624, should be 4576912. Fix? yes
Inode 17629892, i_blocks is 6875624, should be 6875968. Fix? yes
Inode 17629893, i_blocks is 4572824, should be 4572920. Fix? yes
Inode 17629897, i_blocks is 9240, should be 9248. Fix? yes
Inode 17629901, i_blocks is 8168, should be 8176. Fix? yes
Inode 17629909, i_blocks is 8216, should be 8224. Fix? yes
Inode 17629994, i_blocks is 16662856, should be 16662912. Fix? yes
Inode 17630015, i_blocks is 16680376, should be 16680456. Fix? yes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/mapper/c-c: ***** FILE SYSTEM WAS MODIFIED *****
/dev/mapper/c-c: 92144/45400064 files (5.9% non-contiguous), 261799560/726401024 blocks
- chillrAspirantI have this happening as well with my new Duo v2 / 2 x WD20EARX-00PASB0, both HDD's set up as separate volumes Raid0. Pretty disappointing really, does anybody know if this means there has been file corruption?
***** File system check performed at Sat Feb 18 13:38:07 NZDT 2012 *****
Inode 19791884, i_blocks is 64, should be 56. Fix? yes
Inode 19824686, i_blocks is 949440, should be 949448. Fix? yes
Inode 19824751, i_blocks is 939744, should be 939752. Fix? yes
Inode 19825187, i_blocks is 645760, should be 645768. Fix? yes
Inode 19825286, i_blocks is 779536, should be 779544. Fix? yes
Inode 19825294, i_blocks is 779032, should be 779040. Fix? yes
Inode 19825958, i_blocks is 599056, should be 599064. Fix? yes
Inode 19827833, i_blocks is 724712, should be 724720. Fix? yes
Inode 19828062, i_blocks is 524296, should be 524304. Fix? yes
Inode 19828074, i_blocks is 524296, should be 524304. Fix? yes
Inode 19829055, i_blocks is 922960, should be 922968. Fix? yes
Inode 19829065, i_blocks is 575312, should be 575320. Fix? yes
Inode 19829068, i_blocks is 987408, should be 987416. Fix? yes
/dev/mapper/c-c: 6926/30285824 files (1.1% non-contiguous), 248501823/484573184 blocks
Inode 16023555, i_blocks is 732384, should be 732392. Fix? yes
Inode 17499366, i_blocks is 860736, should be 860744. Fix? yes
Inode 17504873, i_blocks is 715568, should be 715576. Fix? yes
Inode 17504893, i_blocks is 792544, should be 792552. Fix? yes
Inode 17504895, i_blocks is 791848, should be 791856. Fix? yes
Inode 17504897, i_blocks is 796280, should be 796288. Fix? yes
Inode 17504899, i_blocks is 738872, should be 738880. Fix? yes
Inode 17504901, i_blocks is 813456, should be 813464. Fix? yes
Inode 17504903, i_blocks is 793392, should be 793400. Fix? yes
Inode 17504905, i_blocks is 797664, should be 797672. Fix? yes
Inode 17504907, i_blocks is 799872, should be 799880. Fix? yes
Inode 17504909, i_blocks is 801704, should be 801712. Fix? yes
Inode 17504911, i_blocks is 802224, should be 802232. Fix? yes
Inode 17504919, i_blocks is 799016, should be 799024. Fix? yes
Inode 17504922, i_blocks is 830536, should be 830544. Fix? yes
Inode 17504925, i_blocks is 989248, should be 989256. Fix? yes
Inode 17504939, i_blocks is 795336, should be 795344. Fix? yes
Inode 17505069, i_blocks is 738600, should be 738608. Fix? yes
Inode 17505071, i_blocks is 671848, should be 671856. Fix? yes
Inode 17505088, i_blocks is 566208, should be 566216. Fix? yes
Inode 17531412, i_blocks is 476008, should be 476016. Fix? yes
Inode 17531421, i_blocks is 478000, should be 478008. Fix? yes
Inode 17531433, i_blocks is 717152, should be 717160. Fix? yes
Inode 17531434, i_blocks is 707696, should be 707704. Fix? yes
Inode 17531435, i_blocks is 716496, should be 716504. Fix? yes
Inode 17531436, i_blocks is 714832, should be 714840. Fix? yes
Inode 17531437, i_blocks is 716416, should be 716424. Fix? yes
Inode 17531438, i_blocks is 717272, should be 717280. Fix? yes
Inode 17531439, i_blocks is 712936, should be 712944. Fix? yes
Inode 17531440, i_blocks is 716280, should be 716288. Fix? yes
Inode 17531441, i_blocks is 719288, should be 719296. Fix? yes
Inode 17531443, i_blocks is 716336, should be 716344. Fix? yes
Inode 17531444, i_blocks is 717000, should be 717008. Fix? yes
Inode 17531446, i_blocks is 717536, should be 717544. Fix? yes
Inode 17531447, i_blocks is 714344, should be 714352. Fix? yes
Inode 17531449, i_blocks is 716680, should be 716688. Fix? yes
Inode 17531450, i_blocks is 713912, should be 713920. Fix? yes
Inode 17531451, i_blocks is 716888, should be 716896. Fix? yes
Inode 17531452, i_blocks is 717736, should be 717744. Fix? yes
Inode 17531515, i_blocks is 358200, should be 358208. Fix? yes
Inode 17531523, i_blocks is 358120, should be 358128. Fix? yes
Inode 17531531, i_blocks is 985936, should be 985944. Fix? yes
Inode 17531566, i_blocks is 718640, should be 718648. Fix? yes
Inode 17531567, i_blocks is 717104, should be 717112. Fix? yes
Inode 17531568, i_blocks is 712216, should be 712224. Fix? yes
Inode 17531569, i_blocks is 712088, should be 712096. Fix? yes
Inode 17531570, i_blocks is 717792, should be 717800. Fix? yes
Inode 17531571, i_blocks is 718032, should be 718040. Fix? yes
Inode 17531572, i_blocks is 711952, should be 711960. Fix? yes
Inode 17531573, i_blocks is 713048, should be 713056. Fix? yes
Inode 17531574, i_blocks is 717488, should be 717496. Fix? yes
Inode 17531575, i_blocks is 715304, should be 715312. Fix? yes
Inode 17531576, i_blocks is 713120, should be 713128. Fix? yes
Inode 17531577, i_blocks is 715328, should be 715336. Fix? yes
Inode 17531578, i_blocks is 715328, should be 715336. Fix? yes
Inode 17531579, i_blocks is 713392, should be 713400. Fix? yes
Inode 17531580, i_blocks is 713440, should be 713448. Fix? yes
Inode 17531581, i_blocks is 712152, should be 712160. Fix? yes
Inode 17531582, i_blocks is 717344, should be 717352. Fix? yes
Inode 17531583, i_blocks is 716816, should be 716824. Fix? yes
Inode 17531584, i_blocks is 716688, should be 716696. Fix? yes
Inode 17531585, i_blocks is 710752, should be 710760. Fix? yes
Inode 17531586, i_blocks is 717464, should be 717472. Fix? yes
Inode 17531587, i_blocks is 717472, should be 717480. Fix? yes
Inode 17531588, i_blocks is 716504, should be 716512. Fix? yes
Inode 17531601, i_blocks is 717760, should be 717768. Fix? yes
Inode 17531636, i_blocks is 380856, should be 380864. Fix? yes
/dev/mapper/d-d: ***** FILE SYSTEM WAS MODIFIED *****
/dev/mapper/d-d: 12183/30285824 files (5.8% non-contiguous), 353526338/484573184 blocks - cynanAspirantI just got my Readynas NV+ V2 up and running a week ago. I have 3x 2TB drives setup in an XRAID array (3.6TB volume). A few days ago, I copied about 100GB of files over to the NAS. Today, I made some config changes and rebooted. I decided to do a volume scan on reboot.
Just like the examples posted above, the volume scan encountered about a dozen or so block errors. Everything seems to be working, however. Is this something to be concerned about? Does this usually happen after copying large amounts of data to/from the NAS?
Edit: There have been no power outages or improper shut downs that I know of and the unit is plugged into a UPS.. Also, I think it is unlikely that the drives are faulty as I did low-level formats on all and all 3 passed all available manufacturer-provided integrity tests (short and long tests in Seatools for DOS) just prior to installing them in the NAS. They were also updated to the recommended (by Netgear) firmware. - StephenBGuru - Experienced UserWhat do the SMART stats say?
- WishAspirantI've just done a volume scan for the first time on my NV+ v2 an has come up with 50+ i_blocks errors like the previous posts.
Smart stats for all 4 drives are good, no errors logged.
I am also wondering if this is something to be concerned about? - janformanAspirantext3 format don't have any i_blocks issue (after reformatting /dev/c/c).
Under ext4 there's no data corruption while fsck found some Inode with incorrect i_blocks number, but it's strange.
Maybe not dangerous, but not normal.
Mounting ext3 as ext4 with quick fsck working fine too.
