nsne
Dec 13, 2015Virtuoso
Volume: System volume root's usage is XX%.
Since adding new HDDs and resyncing, I've been getting the following error message: Volume: System volume root's usage is XX%. This condition should not occur in normal conditions. Contact techni...
nsne
For the sake of posterity, the device logs. I wonder if the ten-minute intervals are exacerbating the problem?
| Sun Dec 13 2015 14:23:22 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 14:13:21 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 14:03:18 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 13:53:17 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 13:43:15 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 13:33:13 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 13:23:10 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 13:13:08 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 13:03:07 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 12:53:05 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 12:43:03 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 12:33:01 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 12:23:59 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 12:13:56 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 12:03:53 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 11:53:51 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 11:43:49 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 11:33:47 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 11:23:45 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 11:13:42 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 11:03:40 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 10:53:38 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 10:43:36 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 10:33:34 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 10:23:32 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 10:16:25 | System: Antivirus scanner definition file was updated to 201512130940. | |
| Sun Dec 13 2015 10:13:29 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 10:03:28 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 9:53:26 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 9:43:24 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 9:33:22 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 9:23:21 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 9:13:18 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 9:03:16 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 8:53:14 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 8:43:12 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 8:33:10 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 8:23:08 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 8:13:06 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 8:03:04 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 7:53:02 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. | |
| Sun Dec 13 2015 7:43:00 | Volume: System volume root's usage is 84%. This condition should not occur in normal conditions. Contact technical support. |
RN314, OS 6.4.1, home network.
mdgm-ntgr
Dec 13, 2015NETGEAR Employee Retired
About 1GB of the 4GB OS partition is being used by the LMS app alone.
# du -csh /var/lib/squeezeboxserver 691M /var/lib/squeezeboxserver 691M total # du -csh /usr/share/squeezeboxserver 307M /usr/share/squeezeboxserver 307M total
When apps store a lot of data on the OS partition that does contribute to getting error messages like this. There are a few other things as well that have contributed to the high root volume usage.
The usage going up then down then back up again would relate to log truncation/pruning presumably.
Most things that are not stored on the data volume would be stored on the root volume.
