vk4akp
Jun 14, 2015Aspirant
Web interface for Offline Use?
Hi,
I'm off to buy a Netgear RN10400-100AJS tomorrow.
My question is.
Do these have the usual normal Web interface via the devices IP address?
Our application is for "Offline" use. IE. No Internet connection on our LAN.
Can we access all features without Internet access or having to run custom software on a PC?
My question is.
- StephenBGuru - Experienced UserIt's best not to do it from the Admin page (using the second link Nhellie posted, or a third-party backup tool like Acronis).
I use the built-in backup jobs to back up the NAS itself - they are not as useful for backing up PCs. - NhellieVirtuoso
vk4akp wrote:
OK. So the unit didn't come with much in the way of manuals.
What's the easiest way to backup a Windows 7 Laptop via the browser Admin page as a quick trial?
Can this be done without adding anything to the Windoze OS? Or does some software need to be installed?
You can find them on KBs', You need to learn about backup jobs and shares. Here are some examples:
http://kb.netgear.com/app/answers/detai ... adynas-os6
or
http://kb.netgear.com/app/answers/detai ... ows-backup
Get more here:
http://kb.netgear.com/app/answers/detai ... -system%3F - vk4akpAspirant
c3po wrote: RN104 and RN314 use 4-pin Kycon connector: Pin 1 and 2 are 12V; Pin 3 and 4 are Ground.
https://en.wikipedia.org/wiki/DC_connector#4-pin
http://www.kycon.com/Pub_Eng_Draw/KPPX-4P.pdf
You can ALWAYS check pin out on power adapter itself. The pin out marking is required by safety regulations.
As long as you can find proper Kycon connector for your power source, you should be able to run RN104 on your 12V power source.
(This reminds me of cutting old connector from broken power adapter and connect it to newer power adapter with incompatible connector)
Cool. Yes I tried to find a pic of the back of the power supply before purchase that could be viewed up close without success.
Now I have it here I have looked and yes it seems to be 12VDC sharing the current across two pin's for Pos & Neg.
The power supply is rated at 7Amps so I guess this was the easiest option for them.
Shame they don't know about Anderson Power Poles. (LOL). Although I guess a smaller option is wanted for retail anyhow.
.-.-. - c3poNETGEAR ExpertRN104 and RN314 use 4-pin Kycon connector: Pin 1 and 2 are 12V; Pin 3 and 4 are Ground.
(This reminds me of cutting old connector from broken power adapter and connect it to newer power adapter with incompatible connector) - StephenBGuru - Experienced User
The web UI reports TiB (1024*1024*1024*1024) not TB (1000*1000*1000*1000).vk4akp wrote: How come a 4TB drive only leaves 3.63TB usable?
OS or Raid overhead or something?
4 TB = ~3.638 TiB.
The OS partition takes 4 GB, so when that is also subtracted it rounds down to 3.63. - vk4akpAspirantWell. Yes you can't turn the thing off when there is no drive installed. Other then pulling the plug. :)
So far very impressed.
The nice App;s for it have really got me keen.
I've installed
-Mysql
-PHPbb
-Asterisk !!!
-Joomla
-PHPsysinfo
Already.. :)
Very interested in DVBLink TV Server as well but I think it requires a payment plan to use it?
I couldn't find any info on this so will look into it later but we have a big need for this. A lot of the houses on our links have poor TV reception.
We have some Aldi Supermarket, Medion MD E89128 / MD86951 USB TV Sticks that I am hoping might be compatible???
Under Windoze it comes up as a RealTek DK DVBT Dongle.. ¿¿¿
I also have to work out what software is needed next to backup all the horrid Windoze machines on the LAN.
Android devices + our Gentoo based servers are also on the list. But at least it seems to support RSync from what I have seen in the menus. :)
OK. 2:30AM here. More soon. :)
.-.-. - NhellieVirtuoso
vk4akp wrote:
- If you start the unit without a drive you can't access the Admin via browser on the IP. You also can't turn the device off with the power button.
Once the drive is inserted it's happy. Instant access to the Admin panel, and auto format of the drive.
-The OS of the NAS is saved on the drives so basically you will just get a "No disk detected" message, about the power button --I believe you can turn if off by pressing it even where theres no drives (as far as I know)vk4akp wrote:
- The drive tray's metal base comes scary close to the drive's PCB. I examined it with a torch and it's lucky to have a 1mm clearance. :(
I almost didn't insert it. Instead I would have been looking for some thin plastic sheeting to insulate it. This would be a nice thing to include actually.
Ha, I can say this is true. But don't worry, haven't seen anyone experience any issues with it.vk4akp wrote:
This is normal, the space is used for firmware or software that the HDD uses, it could also be formatting. - vk4akpAspirantNah. It's a crap store. Low prices (Margins) Zero Support.
You place your order online. Walk in. They bark at you "Name!" regardless what you ask. Then they present the goods and take the cash and you walk out.
If you ring the store you get a message, we are busy now try again later and they hang up. All day every day!LOL!
If I took the device back we wouldn't have anything for months.
Maybe I can buy a spare tray online or something later?
Well it's up and running.
A few interesting quirks that I wasn't overly impressed by but otherwise once into the IP's admin page on the Browser looks very nice so far.
Some interesting feedback.
- The power connector looks very non standard. Where can we buy this plug?
One huge thing we love about Netgear is the use of 12VDC input voltages.
We often buy this brand purely for this reason. (Remote battery / Solar use).
We use a lot of your entry level Switches and Routers that support 12VDC power.
OK, I'm off to play more.
.-.-. - mdgm-ntgrNETGEAR Employee RetiredI wouldn't accept a drive tray not working from the start. I would take it back and get it exchanged for a new unit.
- vk4akpAspirantCool, thanks.
Well we picked one up this arvo. Just about to plug it in now and give it a whirl.
Very impressed with the build quality and double boxing.
Second drive caddy is stuffed from new in ours though sadly.
The latch doesn't work. It came as packed with the second one hanging out the front. (They couldn't close it in the factory). :(
Local RA support is useless at our local store so Meh, guess we're stuck with that, but that's life.
Anyhow will run it up with the 4TB Seagate NAS drive we bought today with it and I'll post my results and opinions here.
Thanks for the feedback to date. :)
