isis1
Apr 09, 2014Aspirant
web interface login issue
Hi, i've just bought a ReadyNas 2120. everything worked fine even after the patch 6.1.6, but after i joined the Domain, the login page is stuck at splash screen. The access to folders is OK, Raidar...
isis1
Apr 15, 2014Aspirant
mdgm wrote: The splash screen issue with Chrome 34 which has now gone stable. Can you try a different web browser or an older version of Chrome?
Solved with IE.
Actually Chrome isn't compatible with nas interface.. i hope they will fix it..
Thanks mdgm
