bcraigie
Aug 20, 2011Aspirant
Web interface stops responding after a while
I have a ReadyNas Duo Name: RAIDiator Version: 4.1.7 Date: Sat Nov 6 00:09:53 2010 (actually, I have two, at different locations, on different networks). I have noticed that ...
NAS_t
Oct 04, 2011Aspirant
@dazman,
Sorry to hear your web server is dying. Mine has been rock-solid since I upgraded my Duo to 4.1.8.
Have you looked through the httpd logs? As I reported above, I observed a SIGTERM (Linux kernel message telling the process to terminate) in the logs whenever the process had died. I was about to go looking through other logs to see if there were error messages happening at the same date/time as the SIGTERMs, but I stopped my investigation after moving to 4.1.8.
You might check your httpd log and see if SIGTERM is what's killing the process. If so, then the next step s to figure out where the SIGTERM is coming from...
Dave
Dave
