BlueMagician
Oct 10, 2011Aspirant
WebDAV in W7? Digest Authentication? Other options?
Dear all, Looking for some help with being able to access my Ultra2 shares using SSL WebDAV in Windows. A little bit of investigation on the matter suggests that Windows7 will only authenticat...
sphardy1
Oct 10, 2011Apprentice
Windows 7 forces the use of Digest authentication which is currently not supported by ReadyNAS from what I can tell.
Until Netgear add support (assuming that they plan to), you may find it easier to configure Windows 7 to use basic auth.
eg http://www.webdavsystem.com/server/docu ... auth_vista
