JimND
Apr 27, 2012Aspirant
What should I have done?
Hi, I've just got a ReadyNAS pro 6, and populated it with three 3TB disks, chosen from your compatibility list. It saw the disk as 750 GB at first, but it updated its Raidiator version from your sit...
ReadySECURE
Apr 27, 2012Apprentice
As you have found, there is not currently a way to achieve a flush of configurations and add-ons to get a "raw install" state, without losing the data. I would recommend backing up all data and configurations prior to introducing something new to the system for situations like this. With rootSSH you can access the device and make alterations, as you know, to remove things like this that cause issues, if you are familiar enough with the system.
The OS reinstall procedure corrects OS corruptions, and resets the NIC settings and the admin sign-in, and additionally clearing the logs. This will not remove or uninstall any add-ons that you have installed.
