alanderego
Apr 21, 2013Aspirant
What size external USB drive do I need?
Hi everybody. I have never backed up my ReadyNAS, but I need to do a factory reset because my NAS will not expand (I just finally installed 4 x 2TB drives.) My current usage is 86% of 4114 GB (3538 ...
alanderego
Apr 24, 2013Aspirant
Thanks again, but the only thing is that I only have laptops with only 500GB of storage.
Can I work with this?
On a side note, Is there a way to check the progress of the backup?
I have been trying to backup 750GB share for the past 2 days.
Every night I get an error message "A previous run of backup job is still running. Check if that backup job has stalled, or you may need to adjust the backup interval to account for the amount of data you are backing up. [Job 001]", but under backup jobs it still says in progress.
Thanks,
Alan
Thanks,
Alan
