Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
mdgm-ntgr
Mar 05, 2012NETGEAR Employee Retired
Don't get that. Get a switch e.g. the GS108T. Connect the switch to the router and plug the ReadyNAS units into the switch. Problem solved.
That way you can access all the NAS units via gigabit ethernet. If your router is not gigabit then you could connect your PCs to the switch as well (if they are connected via ethernet) to get gigabit speeds.
