Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
mdgm-ntgr
Mar 06, 2012NETGEAR Employee Retired
A switch just provides ethernet. A router will do both ethernet and wireless. Also a router typically can be used as the device that assigns IP addresses.
