Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
Mar 06, 2012Guru - Experienced User
Yikes. Hopefully you are not overloading your circuits.
anarchoi wrote: awww i thought i could replace my router with the switch... problem is that i dont have any free power outlet left in this room (and i am already using power surge protectors with 12 outlets)... I'd prefer to buy a switch with wifi, or a router with 5 ports or more, if possible
Thanks for help guys
I don't know of any wifi+gigabit routers that have more than 4 ethernet ports, and you can't use a switch without a router.
You probably should have a UPS for the duo anyway, and that would have enough outlets to cover your router and the switch. so that would be one way around your outlet problem.
