Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
Retired_Member
Mar 06, 2012
You probably should have a UPS for the duo anyway, and that would have enough outlets to cover your router and the switch. so that would be one way around your outlet problem.
Is it really worth the money ? I never have electric failture here... My computer has been on 24/7 for years and never had any problem... All of my stuff is plugged in a Belkin surge protector, they guarantee up to $200,000 worth of equippement is something blow up.... should i still get an UPS ?
I don't really want to buy a switch if im still forced to use my router... Anyway the switch would be used only for one ReadyNas Duo, and i dont use it very often (damn i wish i could just plug it with USB)... That's why i wouldn't mind getting wireless connection and i dont care if i get slow speeds... If the NETGEAR WNCE2001 can work with the ReadyNas Duo i may buy it
Another off-topic question, is it normal that i am getting only 10mb/s write speed when i transfer files to any of my ReadyNas Ultra 4 Plus ? I'm using cat6 cables with a Belkin F5D8233-4 router
