Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
Retired_Member
Mar 06, 2012
I guess you need to decide if you care about speed or not. Your post is sending a mixed message.
Do you have a Duo and an ultra 4 plus? If so, are you using the duo for primary storage or backup?
Sorry, let me give more details
First i bought a ReadyNad Duo and realised i couldn't use it with 3TB drives. So i bought a ReadyNas Ultra Plus and really liked it, so i bought another.
Those two ReadyNas Ultras are my primary stockage NAS. I care about the speed of my Ultras.
Now i'm left with another ReadyNad Duo i didn't know what to do with, so i'm using it to store old files. I really don't care about the speed of my ReadyNas Duo since it is almost read-only.
Anyway do you really mean 10 megabits, or do you mean 10 megabytes? Your router is only capable of about 10 megabytes (100 megabits). You should be getting more than 10 mb/s.
I meant that when i am transferring files from windows to NAS, windows tell me the speed is 10mb/s. This is really slow and i have same problem on all of my NAS.
