Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
mdgm-ntgr
Mar 06, 2012NETGEAR Employee Retired
anarchoi wrote:
- Is it dangerous to plug my UPS into my belkin surge protector ? usually it is not recommanded to plug an extension into a surge protector, is it the same thing with an UPS
You should buy a UPS with surge protection and not plug it into a surge protector.
anarchoi wrote:
- APC and UPS is the same thing or not ?
APC is one brand of UPS available. They are other brands such as CyberPower.
anarchoi wrote:
Good choice ? Enough watts for all of my stuff ?
Have a look at the watts your devices use. You should not load the UPS with more than 80% load. If you put too heavy a load (over 80%) on the UPS the battery will drain too quickly in the event of a power failure shortening it's life.
