Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
Retired_Member
Mar 06, 2012Ok i finally decided to buy the CP1350AVRLCD from newegg... One problem solved !
Been looking for a solution to the other problem and i came across this:
http://www.newegg.ca/Product/Product.as ... 6833122446
newegg lists it as a "firewall" and netgear says it is a router :
http://www.netgear.fr/images/FVS318N_fr65-36060.pdf
Can i use it as a router and just replace my belkin with it ? I don't even know the difference between a normal router and hardware firewall :/
