Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
Mar 07, 2012Guru - Experienced User
I don't know why the directcanada site says it is "draft n" - that has to be incorrect, no router introduced in Q4 2011 would be draft n. 802.11n was completed in October 2009.
anarchoi wrote: damn i'm stupid, i meant i was about to buy the netgear router not the belkin one, sorry, i don't know why i wrote belkin, need some sleep i think.
i want to buy this one:
http://www.directcanada.com/products/?s ... re=NETGEAR
earlier you said "draft n" wifi might be a problem, thats why i was asking the question since the 8-port netgear router is also "draft n"
