Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
Retired_Member
Mar 07, 2012Ok, maybe that's why it isn't listed as "draft n" at newegg.
Just bought the router from DirectCanada... Guess all my problems are solved now. Thanks again :)
