Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
Mar 08, 2012Guru - Experienced User
The cable grade is printed on them - I believe it is likely Cat 5. These will usually work (since they are very short), though if you have a cat 5e or cat 6 patch cable you should probably use that.
I'm not sure why Netgear ships Cat 5 with a gigabit product.
