Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
Mar 10, 2012Guru - Experienced User
Did you connect the USB cable between the UPS and the NAS? Also does Frontview tell you that the NAS is monitoring the UPS?
