Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
mdgm-ntgr
Mar 10, 2012NETGEAR Employee Retired
anarchoi wrote: Oh i thought it was monitoring it through ethernet...
That USB slot on the CyberPower is already used to link my computer to the UPS. How can i also link my 2 NAS ? Will it work if i use a USB hub ?
I suppose i have to plug the usb cable on the back of the NAS and not the front ?
Connect the USB to one device and use NUT to share it over your network (obviously both devices' power cables will need to be connected to the UPS and the power cable for the router/switch as well for this too work). See Using the ReadyNAS to create a Network UPS for PCs
