Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
mdgm-ntgr
Mar 10, 2012NETGEAR Employee Retired
If you can get the PC to share it over your network using NUT then it can probably be shared with the NAS.
