Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
Retired_Member
Mar 11, 2012
I don't use WinNUT so I can only give general advice. Did you try disabling your Windows Firewall?
Also, remember to connect your new router to the battery-backed side of the UPS.
Is there another way to do it without WinNut ?
And yes, Windows Firewall is disabled. Router is also plugged in the UPS battery
