Retired_Member
Mar 05, 2012Wifi with Readynas Duo
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable... My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wif...
Mar 11, 2012Guru - Experienced User
Not that I know of. Most of the guides are set up assuming that the UPS is connected to the NAS and monitored by the PC over the network (opposite from what you are trying to do). Maybe someone more experienced with WinNut will respond with the right settings.
anarchoi wrote: Is there another way to do it without WinNut ?
