Retired_Member
Apr 12, 2012Wow my ReadyNAS Ultra won't start anymore
I have a ReadyNAS Ultra 4 ... i bought it only a few months ago, it's brand new and i barely used it Today i tryed to start it... The blue LED light and the LCD screen powered up, then it power dow...
mdgm-ntgr
Apr 14, 2012NETGEAR Employee Retired
It's highly unlikely to wipe out all your data if all the disks are fine. Rearranging the order is not recommended but should be O.K.
See the below quote from the FAQ (emphasis mine): http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
If you're really worried you could ask support if a tech can remotely login and examine the situation. Tech support mode is a low level diagnostics mode and booting into this mode in itself doesn't touch the disks.
If you want to check the SMART stats connecting the drives to a PC, I think there are some free tools to do this. Haven't used any so I don't know how well they work.
NetGear wrote:
Although not required, it's always a good idea to keep the ordering the same.
