Loy
Feb 28, 2015Aspirant
Yosemite: no Frontview and CFIS mount
Hi, I'm using a ReadyNAS Duo V1 with FW4.1.14 RAIDar showed everything is fine. I'm not able to access Frontview with my mac devices like Macbook pro Yosemite safari and can't see CIFS mount in...
mdgm-ntgr
Feb 28, 2015NETGEAR Employee Retired
Sounds like the RAM has failed. You will need to replace the RAM (not supported - be sure to run the memory test at least a few times before trusting it) or
purchase a new ReadyNAS e.g. RN312 and contact support. Wait for advice from support. Don't put the disks into the new NAS until prompted to by support. Note there may be a charge for this.
