Loy
Feb 28, 2015Aspirant
Yosemite: no Frontview and CFIS mount
Hi, I'm using a ReadyNAS Duo V1 with FW4.1.14 RAIDar showed everything is fine. I'm not able to access Frontview with my mac devices like Macbook pro Yosemite safari and can't see CIFS mount in...
mdgm-ntgr
Mar 01, 2015NETGEAR Employee Retired
diagnostics.log indicates this:
Your disk smart logs also indicate that there is a problem with your WD disk.
Memory
* Found errors on your system that are generally caused by bad memory. Please contact support about this issue.
