BowQtr's avatar
BowQtr
Follower
Mar 12, 2021
Status:
New Idea
Insight Clients module - add more wireless fields to help investigations
In the client section of the Insight App, it would be useful to see additional information against each device, for instance, which channel frequency are they using 2.4 to 5Ghz, what channel are they using, what 802.11xx mode are they using, what WPA mode did they authenticate with, the RSSI signal strength, are they using a private MAC address (on a modern phone) - adding fields (and others) such as these into the Client's page would help with diagnosing connection problems.
Also would be good to be able to click on a client in the browser and see its history, so when it connect, disconnect, change AP if roamed, connect again etc, so we can see a history of the wireless client with relevant fields that will allow us to diagnose connectivity problems.
2 Comments
  • schumaku's avatar
    schumaku
    A good part of what you are looking for here is readily available on the Insight Web portal, including romaing history, security, channel, signal level, ...
  • I would also like to see the username available when a client has connected via radius and not "Unknown u
